New AR ran vag-com comments on codes
Just ran my vag-com and came up with these codes:
Thursday,15,November,2007,21:44:16:07912
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WA1YD54B14N003976
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 02325
WA1YD54B14N003976 AUZ7Z0C2411136
1 Fault Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 4Z7-927-156.LBL
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01002
Shop #: WSC 02325
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: None
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 02325
1 Fault Found:
01119 - Gear Recognition Signal
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01449 - Switch for Driver Seat; Tilt Adjust (E222); Back
28-10 - Short to Plus - Intermittent
Address 56: Radio Labels: None
Part No: 4B0 035 195 N
Component: symphony II NP2 0260
Coding: 02005
Shop #: WSC 70656
2 Faults Found:
65535 - Internal Control Module Memory Error
08-10 - Control Limit Surpassed - Intermittent
Address 65: Tire Pressure Labels: 4D0-907-273.LBL
Part No: 4D0 907 273 A
Component: Reifendruckueberw. D210
Coding: 22307
Shop #: WSC 02325
5 Faults Found:
01467 - Front Left Tire Pressure Sensor (G222)
53-00 - Supply Voltage Too Low
01468 - Front Right Tire Pressure Sensor (G223)
01469 - Rear Left Tire Pressure Sensor (G224)
01470 - Rear Right Tire Pressure Sensor (G225)
01521 - Sensor for Tire Pressure
53-10 - Supply Voltage Too Low - Intermittent
Car runs fine, no cel light, first run abs did not even show fault. The tpms doesn't calibrate. Car has 31k miles and all service. Suggestions???
Thanks everyone<ul><li><a href="http://www.mjposner.com">http://www.mjposner.com</a</li></ul>
76 77
Coding: 07755
Shop #: WSC 02325
1 Fault Found:
Coding: 01002
Shop #: WSC 02325
1 Fault Found:
Coding: 06497
Shop #: WSC 02325
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 02005
Shop #: WSC 70656
2 Faults Found:
Coding: 22307
Shop #: WSC 02325
5 Faults Found:
1.yeap, del all and drive a bit see if they come back
2. check service history to see if some of this has been addressed in the past
or go to the dealer let them run a scan and repair under CPO if you have one
good luck
good luck
Pete K (vegasguy)
VAG-COM Discussion
12-13-2007 02:10 PM
2point7LI
12-29-2006 05:29 AM
