New key battery, reprogrammed per manual and it will lock/unlock for 15 mins. Then the car forgets
all over again. I haven't scanned yet. I will when I get home. I was wondering if anyone has had and solved this problem in the past.
Sunday,15,March,2009,14:53:55:49804
VCDS Version: Release 805.2
Data version: 20090111
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WA1YD64B34N013642
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 02325
WA1YD64B34N013642 AUZ7Z0C2415702
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01002
Shop #: WSC 02325
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 02325
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 2000
Coding: 0000607
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 06264
Shop #: WSC 02325
Address 34: Level Control Labels:
Note: Excessive Comm Errors
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15917
Shop #: WSC 06158
4 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02325
Address 56: Radio Labels: None
Part No: 4B0 035 195 N
Component: symphony II NP2 0260
Coding: 0200
76 77
Coding: 07755
Shop #: WSC 02325
1 Fault Found:
Coding: 01002
Shop #: WSC 02325
Coding: 06497
Shop #: WSC 02325
Coding: 00010
Shop #: WSC 02325
Coding: 0000607
Coding: 01002
Shop #: WSC 02325
Coding: 06264
Shop #: WSC 02325
Coding: 15917
Shop #: WSC 06158
4 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02325
Coding: 0200
I ordered a new key today and a new door lock (broken micro switch) After I get the lock on and the new key programmed (along with old) I will be able to eliminate the key and the faulty door lock.
I'll mess around with it. I'm am going to go home and get on the computer running XP so I can load the Bentley and check the wiring diagram.
My microswitch on the drivers side is bad so I have a new lock on the way and a new key as well to see if the key was the issue.
cutchemist42
06-07-2013 04:19 AM
DoubleB
VAG-COM Discussion
03-10-2009 04:48 AM
Nutch
VAG-COM Discussion
06-07-2007 07:43 AM
