A new and novel Allroad suspension problem
Hi,
I have spent a long time reading all the forums about the Allroad air suspension system. But no-one appears to have experienced the problem I currently have.
The suspension on the right side of my 2000 2.5 tdi Allroad is collapsing when the car is turned off. I have Arnott front suspension units and the original Audi units in the back. We have just recoditioned the pump with a piston reconditioning kit and the pump seems to be working OK. Also cant seem to find any leaks in the system. Car will pump up after a while but always collapses again once the car is turned off.
VAGcom is returning 01776 and 01400 errors which seem to indicate there is a problem with the control head which distributes the pressurised air to the individual struts or the suspension ECU.
Anyone else seen this problem and if so what was the solution?
Paul
Paul
Hi,
Paul
Paul
If no leak is found, valve N149 and N151 may not be closing properly either due to power begin applied to them at the wrong time or low lubrication in valve.
Either case it seem odd that only the right side leak down. But then again it happens.
