NEW Rebuild Kit for the Allroad Suspension Compressor - Piston Ring
#11
How have I not found this before? I've known my compressor is on borrowed time since I bought it. It holds at #1 fine but try moving up to #2, #3, or #4 is hit or miss and usually times out.
I will have to give this a try as I've always thought it was nuts to have to replace the whole compressor of ~$400 or so.
#12
I ordered the compressor rebuild kit just last week. Should be here any day now. I presume he makes them available in batches. When I bought mine, Ebay said there was one left. I understand though that they become available fairly regularly.
#13
Yes, he does make them in batches at a time, and does ship to the US.
#14
Just received mine yesterday and installed it an hour ago. I too saw the no US shipping bit when I went to purchase it so I sent him an email. He was having issues getting them insure but has since resolved that and they are back for sale on ebay with US shipping! I have yet to crawl back under and install it as I'm dealing with another suspension mystery issue and a connector that was corroded, but will report back with results when I do. Damn you and your salt, MN.
On another note, did anyone else who replaced this notice any difference in diameter on the piston ring? Is the point of replacement just to get it's springiness back so it makes contact with the cylinder bore? I guess I had a hard time telling what was wrong with my original aside from a slight sheen. It does not seem like the compressor has close enough tolerances for it NOT to be a visual difference.
A last note, as stated in the directions, my O-ring was the formed variety so I reused my old one with some VAG gasket maker. I also ran into the replacement bolts being slightly too long so again reused the old ones with some blue thread lock. Not a big deal but don't be surprised!
#15
Im getting ready to order one of these kits, and i was wondering about how long it took you guys to do the repair? Has everyone had good results? it takes FOR-EV-ER to change levels in my car now...
#16
Hey guys,
Are these still around? I tried searching e-bay but have not had much luck. I will just eat it and buy the complete pump if I have to, but saving a few bucks as always a nice thing
Chris
Chris
#17
http://www.ebay.co.uk/sch/bagpipinga...&_trksid=p3686
Any questions please just ask
best regards
Andy
#18
Thanks Andy. I will give one of these a try. Thanks for the fast response.
Kind Regards,
Chris
Kind Regards,
Chris
HI Chris, yes still for sale see link to my items:
best regards
Andy
best regards
Andy
#19
best regards
Andy
#20
That's what it's doing! It seems to gets really bad in the winter time here in Colorado. But that makes sense the more I think about it. I bet the rubber rings shrink on the piston in the cold allowing more air to leak past them and in the summer, they expand in the heat and the system works fairly well then.
Thanks again. I just ordered a kit from you
Chris
Chris
No Problem, typical symptoms of a tired compressor is, when lifting from 1-2 or higher if it takes more than 120 seconds each level the suspension error light will come on, but turn ignition off and on again, it will clear the error, and pressing up it will try again, this is very typical of a tired compressor on the allroad, the kit will renew the compression good as new ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
best regards
Andy
best regards
Andy
