No first gear!? Anyone with the same problem? Newbie
No first gear!? Or reverse! Limpmode. Anyone with the same problem? TIP Transmission
Hi there
I checked around but did not see anyone with this problem..
So I put this thread in:
Allroad 2001 Aut, the first gear does not engage!
Anyone with the same issue?
Or better off, a solution!
Thank You
Thank You
Last edited by glennlindh; 02-09-2016 at 08:18 PM. Reason: Change the title so I get more viewers
Oh I forgot to add, the rig drives and runs perfect, except that it starts in the second gear!
Other than that, no issues, thu my dash cluster/LCD display is the typical problem
I need a new LCD display..
fault codes? Do you service the vehicle by yourself Or in a garage?
I "fix" my rig myself, thu I don't have a code reader for VW/AUDI..
I need to get hold of one asap
Yeah, I might have to go to a shop for the reading til I manage to buy one
Anyone who knows a Audi, a decent and good Audi dealer/shop at the west coast/middle area of Oregon?
I live in Coos Bay
I live in Coos Bay
I bought the Ross Tech WIFI..
And did my scans
I tug in all cables, had the "computers" out, all seems like new!
This is my scan/scans:
VCDS Mobile 0.4222.0.4
Chassis Type:4B
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No SW: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0002
Coding: 06752
Shop #: WSC 02325 000
VCID: 4BD9F42F69A511B7E4E142-5184
Subsystem 1 - Part No SW: WAU-YP5-4B5-1N1
Component: 47181 AUZ7Z0A1798088
2 Faults Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No SW: 4Z7 907 389
Component: ABS/ESP allrad D5702
Coding: 06397
Shop #: WSC 23320 000
VCID: 09550E27235943A7164D18-5184
1 Fault Found:
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000 000
VCID: 2D1D9AB7F7713F87DAD58C-4B3C
No fault codes found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No SW: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00160
VCID: 60833383F023A2EF21D35D-25A6
1 Fault Found:
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No SW: 4Z7 959 655 C
Component: Airbag Front+Kopf 2002
Coding: 00407
VCID: 4FE1E03F9DBD2D97880916-51A8
1 Fault Found:
01213 - Belt Tensioner Igniter; Rear Middle (N198)
32-10 - Resistance Too High - Intermittent
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No SW: 4B0 907 487 L
Component: Lenkradelektronik D03
Coding: 00112
Shop #: WSC 65535 000
VCID: 352DB2D71F217747A20534-4FFC
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No SW: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
VCID: 43C9DC0F41F5D9F71CB19A-5184
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Address 34: Level Control Labels: None
Part No SW: 4Z7
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999 000
VCID: C5CD4217CFC167C7B2A504-5184
2 Faults Found:
01316 - ABS Control Module
79-00 - Please Check Fault Codes
01769 - Sensor for Vehicle Leveling; Front Right (G289)
57-00 - Electric Circuit Failure
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No SW: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
VCID: 302383C3E043526FF1F36D-4EEA
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01560 - Passenger Door
59-00 - Can't Unlock
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
VCID: 2C1B97B3CC6B368FCDAB99-4B3C
3 Faults Found:
01445 - Sensor for Driver Seat Fore/Aft (G227)
29-00 - Short to Ground
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
29-10 - Short to Ground - Intermittent
20-00 - Malfunction in Basic Setting
Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl
Part No SW: 4B0 919 887 B
Component: Navigation BNO 0001
VCID: 322789CBEE4F607F87E757-4B1E
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No SW: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
VCID: 260F659BD2870CDF1B6FDB-5160
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No SW: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
VCID: 044B1F13047B1ECF653B51-4B9A
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No SW: 4B0 035 195 A
Component: Radio D00
Coding: 00114
VCID: 1E7F4D7B8AD7D41F533F33-4B9A
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No SW: 8Z0 919 283
Component: Parkingsyst. A6 RDW D05
Coding: 01186
VCID: 0247190B1E6F10FF570767-5184
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
31-00 - Open or Short to Ground
And did my scans
Chassis Type:4B
75 76 77
Coding: 06752
2 Faults Found:
Coding: 06397
1 Fault Found:
Coding: 00003
Coding: 00160
1 Fault Found:
Coding: 00407
1 Fault Found:
Coding: 00112
Coding: 02264
1 Fault Found:
Part No SW: 4Z7
Coding: 25500
2 Faults Found:
Coding: 15885
4 Faults Found:
35-00 - -
35-00 - -
Coding: 00001
3 Faults Found:
1 Fault Found:
00-00 - -
Coding: 00102
Coding: 00030
Coding: 00114
Coding: 01186
1 Fault Found:
Yesterday then I scan it again, it did not show any fault codes at all except the: 2 Faults Found:
