Normal for coilpacks to go in pairs? I replaced 2 about 6 months ago...
Old 03-09-2009, 07:34 AM
edouble's Avatar
Default Normal for coilpacks to go in pairs? I replaced 2 about 6 months ago...
was getting the blinking CEL and the misfires, had it scanned, showed cylinder 3 and 6 misfires. Recently have been feeling a misfire here and there, assumed coilpack, had it scanned, cylinder 2 and 5. Coincidence???
Old 03-09-2009, 07:44 AM
paulroad's Avatar
Default had the same happen...
its not always, but it does happen.
At this point I'd change all of the originals.
Old 03-09-2009, 08:48 AM
edouble's Avatar
Agreed, I'm going to order the final 2 this week...
Old 03-09-2009, 09:27 AM
ColoradoSpringsAR's Avatar
Default So what causes these things to go out? ...
I've had my 2001 now for about 25K miles and I've never replaced one. I'm not sure what the the previous owner may have replaced, but it sounds like I should always keep some in the car just in case. Is this a "borrowed time" issue like not replacing a timing belt until 120K miles or are the failure more random than that?
Old 03-09-2009, 10:05 AM
New Member
tjallroad's Avatar
Default I've wondered that myself. The 3 times my cp's have failed they failed 2 at a time.
I've always replaced all 6 of them each time.
Old 03-09-2009, 10:07 AM
edouble's Avatar
Default There are posts on here that seem to indicate that 2001 models...
do not have the same coilpacks as later models and thus do not have the same issues with them failing. Mine is a 2004. That being said, I replaced the first 2 at about 80k miles and the 2 I just replaced were at 88k. Some seem to have to replace them much earlier and others later, not sure why.
Old 03-09-2009, 10:08 AM
edouble's Avatar
Also, both times for me were side by side cylinders, not sure if that is coincidence or not.
Old 03-09-2009, 10:22 AM
O2Allroad's Avatar
Have an 02 with the original old style coilpacks at 84K miles
Old 03-09-2009, 05:07 PM
Member
girlroad's Avatar
'01 with 120k on the originals...plugs changed cp's still good
Old 03-09-2009, 05:30 PM
New Member
drivingforever's Avatar
Default Two of mine went within a week of each other.
Cylinder nos. 4 and 1 went within a week of each other. They were L code coils, on my '03 2.7.
Depending on the misfires, the scan might show two or more cylinders misfiring when only one actually is. Try scanning it while driving or just after driving, and see if any codes are pending. The first one/most common one that shows up is probably the culprit.
jujuC6
11-27-2011 03:57 PM
supawyde
01-24-2008 10:36 PM
Zephead007
04-27-2007 07:29 PM
widstje
1.8T Discussion
06-22-2006 05:28 PM
Quick Reply: Normal for coilpacks to go in pairs? I replaced 2 about 6 months ago...
