O.CT Stage 1
- basically the B5RS4 has an airbox with a flap that opens under higher boost / load to get more airflow (by cutting a hole in your box you are basically doing the same thing)
- search "darin intake" on the B5S4 forum (every single high hp S4 until very recently is running this setup - some now have an open element filter sitting inside a carbon fiber shield but trust me when I say, keep the filter stock (you MAF does not like oil) and there is nothing you can do to your car that will require more airflow) - I have one of the highest horsepower S4s in the world and I'm running a stock filter with a hole cut into the bottom of the box - I also have one of only a few K04 Allroads and I'm also using this setup
- save your money for HSports, Stoptech brakes and K04 turbos
because of it, or none at all(hence without air filter comment). Since you are pushing so much hp you might be getting to the area where the filter is a restriction. I know the guys have been running dyno test without exhaust(cutouts) at EPL, just was curious if there was any air filter restriction(hp loss) tests.
PILL PUSHER
09-25-2007 06:17 AM
UrSoccer_mobileĀ®
12v V6 Discussion
12
10-17-2003 05:30 AM
CrayonSpear
04-15-2002 06:47 PM
