O2 sensors and EGT replacement this week
I am replacing my O2 sensors and 1 EGT sensor this week because I scanned my 2001 allroad and found the following:
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-00 - -
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0010 0001
Is there a site or tech article explaining which bank is which? I really need to know which EGT is side 2 because I am only ordering the one I need. I am replacing all 4 O2 sensors since 3 seem to be shot at this point.
Thanks,
Joe
P0134 - 35-00 - -
P1113 - 35-00 - -
Thanks,
Joe
Check with your audi dealer before you spend money on the EGT temp sensors. There is AUDI TSB on 2001 Allroads where a simple ECU Reflash with software update will stop the check engine light from coming on with that fault code. Only certain VIN number ranges were affected with a specific ECU part number. We had this procedure done in Sacramento and it fixed our CEL issue with no reoccurence after 1 year. Good Luck on the O2 sensors the left pre-cat one is real fun to change.
P0134 - 35-00 - -
P1113 - 35-00 - -
Thanks,
Joe
P0134 - 35-00 - -
P1113 - 35-00 - -
Thanks,
Joe
raiderrider
12
09-08-2015 05:46 AM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
giuseppepat
09-02-2015 02:47 AM
