OK... I give up... what's Lemmiwinks??
I did a google search and only found Southpark references. Funny thing is, I don't even remember which southpark episode dealt with Lemmiwinks.
more explanation. Oh yeah: Don't start screwing with this unless you know what you are doing.
Ch01 : Idle Speed Offset
Adjust idle RPM level
- Higher number: increase idle rpm
- Lower number: decrease idle rpm
Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
-This channel adjusts a fuel enrichment under load
-Modulates Throttle Response
Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
-This channel adjusts a fuel enrichment term coming off the gas or decelerating.
Ch04 : Start Up Fuel Enrich
Amount of fuel on any start ups?
- Higher number: enrich the mix
- Lower number: lean out the mix
Ch05 : Warm Up fuel Enrich
Amount of fuel on start ups E.G. on the first start in the morning?
Ch06 : Lambda Regulation
Controls how fast ECU adapts:
- Higher number: faster adaptation
- Lower number: slower adaptation
Ch07 : Additive Offset To Speed Limiter
Controls speed limiter in increments ok 1km/hr
Ch08 : Secondary Fuel Tweak
It adjust gain on the injectors responce
- Higher number will increase the injector responce (smooths the ride)
- Lower number will decrease injector responce (decrease backfires)
Ch09 : Ignition Timing Offset
Controls timing in steps of 0.75 degrees, all RPM range is altered
- Higher number advances timing
- Lower number retards timing
Ch10 : Primary Fuel Tweak
Controls fueling on run, ussually change multiplicative fuel trims
- Higher number enrich the mix
- Lower number lean out the mix
Ch11 : Unused
Unused
Ch12 : SEL Scaling (Turbo Cars Only)
Adjust fueling maps according to boost settings
- Higher number increase injection period for higher boost
- Lower number decrease injection period for lower boost
Ch13 : OFF OFF
Unused
Ch14 : Idle Torque Additive Offset
Controls engine load at idle
- Higher numbers: spec load at idle is increased
- Lower numbers: spec load at idle is decreased
Ch11 : Unused
Unused
Ch13 : OFF OFF
Unused
BSK auf Arbeit
06-22-2006 12:21 AM
BSK auf Arbeit
12-06-2005 02:57 PM
Woland
16
04-19-2005 10:45 AM
