Paging allroad2001 or anyone who may have an original outer CV joint laying around
I am still having a problem with ESP engaging during WOT, full boost conditions in 3rd and 4th gear. I have checked the sensors and they are intact, clean, and mounted flush. The only thing I can think of is that the tone rings are out of spec on the new axles I got from Raxles. I would like to compare detailed info like number of teeth, spacing, overall diameter, etc.
Does anyone have a joint/axle handy that could take some measurments?
This is the only comparison I have right now:
Old
<img src="http://www.mcqfamily.com/allroad/raxles/old_outer.JPG">
New
<img src="http://www.mcqfamily.com/allroad/raxles/raxles_order3.jpg">
Old
New
This happened on the GTI after the coil overs were installed. Its a 5 minute process and on the Ross-Tech site.
on file, not sure how much of a help that is:
A6 front CV joint M16x1.5 has 45 teeth on the ABS ring, Part number 85212, identical with the allroad part number as I found on different websites.
This is also applicable for the early A6 2.8, the A4 and A8, all the same.
Do you have access to an oscilloscope? I would scope the fronts and compare the signal to the rears.<ul><li><a href="http://sjmautotechnik.com/trouble_shooting/brake.html">http://sjmautotechnik.com/trouble_shooting/brake.html</a</li></ul>
laptop.<ul><li><a href="http://polly.phys.msu.ru/~zeld/oscill.html">http://polly.phys.msu.ru/~zeld/oscill.html</a</li></ul>
The blocks are there, but it won't let you log while moving.
Thanks for the links. I guess I might have to get more creative as you suggest.
I wonder also if there is any possibility that a slightly slipping clutch could be causing this.
