paging suspension guru's!
All was fine, until a 300 mile run through a -7oC snowstorm...
The level light on the dash came on whilst driving. Stopped for fuel. Turned ignition back on and light went off. Left for two days and drivers side rear corner was on the floor. So I thought time to call arnott for a replacement spring. However I thought i'd check the DTC's first and it appears I have bigger problems![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 A
Component: - 2C1A1 X019
Coding: 25500
Shop #: WSC 09999
6 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
01776 - Control Head for Vehicle Leveling System (E281)
57-10 - Electric Circuit Failure - Intermittent
00774 - Level Control System Sensor; Left Rear (G76)
01769 - Sensor for Vehicle Leveling; Front Right (G289)
01771 - Control Module for Headlight Range (J431)
79-10 - Please Check Fault Codes - Intermittent
So i was wondering are these all symptoms of a leaking bag?? Could somebody give me a logical order of things to check? Any help appreciated!
Coding: 25500
Shop #: WSC 09999
6 Faults Found:
gruvenparts.com
10-11-2016 04:47 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
