Piggie pipes DIY on allroad- easier?
I think I read it here but the damn STFA isnt working still. There was some mention about doing Piggies DIY on the allroad being easier than the S4.
Something about dropping the crossmember or something.. anyone have some info or pics? I have no issue following the S4 guide(s), but I dont want to go loosening random bolts that aid me at all.
Yeah, Ive read that. The very first paragraph starts with the DPs already out of the car! Its the steps before that I was questioning.
Think we crossed wires here. I know I have to remove the DPs. Ive done it on my S4 before. Im following a S4 centric guide, but there are additional hoses on the allroad and the DP bolt positions seem to be slightly rotated, I cant reach the top one. This is not how it was on my S4 or in the guide.
I read previously its meant to be easier on the allroad and something about dropping the engine down while supporting it on a jack. I just wanted more info on the actual removal process on the allroad. Gutting the precats will be comparitively easy when I get to that point.
For anyone else doing this later, I undid the bolts on the subframe (as if installing an AWE DTS, see their install guide) then threaded them back in slightly. I supported the engine with a hydraulic jack on the transmission (not sure if that is the trans actually, its to the left of the car near the oil pan). If anyone knows a better place to support, please advise. I also put a tripod Jack stand upsidedown (so the "tripod" legs point up) under the Oil pan as a precaution.
When lowering the bolts you can see the area you need to get at (assuming you have removed the driveshaft shields and the hose clip on the DP heatshields) from the side of the car, as opposed directly under it. May still have to get the top bolt on the DP from above tho. Gale force winds chased me out of my garden and cut the project short again.
KillA6
NY / NJ / CT Discussion
20
12-04-2007 06:02 AM
iNfiNkC
04-24-2007 10:28 AM
SantorinSteve
Florida Discussion
04-14-2003 08:20 PM
jatava
03-28-2003 11:31 AM
