Please someone with bently manual, what is the torque for 10m triple square bolts???
I have searched everywhere and torque is all over the place, some say 30 ft lbs, some say 40 ft lbs, some even say 51 ft lbs or 57 ft lbs. Please for the love of god can someone look and see what the torque value is for 10m triple square bolts for a 2002 audi allroad is? Also does it say anything about using loctite? really wish I had the manual for this car.
also if your bored could you confirm these torque values?
Halfshaft outer bolt- 140 ft lbs pluse 180degrees
Caliper bracket big bolts- 148 ft lbs
caliper guide pins- 22 ft lbs
rear brakes guild bolt- 25 ft lbs
rear brakes big bracket bolts- 95 ft lbs.
I am pretty sure the brake torques are correct since I found a bently manual with pics but where the hell is the vag faqs bently manual for half shafts for the bastard?
Well I did find this and it does say 2001-2004 audi all road so I guess I am going to go with 51 ftlb or 70nm on the M10 12 point bolt I guess, hopefully this is right.
http://www.vaglinks.com/Docs/Audi/C5...gServicing.pdf
bingS4
06-06-2008 05:57 PM
BigMouse
09-13-2001 02:41 PM
