PSK 18mm rear sway bar from A6, will it fit the ar?
Checked archives for a bigger rear sway bar. All I've come up with is A6 stuff, thought maybe since their the same platform the bigger bar might fit. I just traded my avant for the ar and the handling of the two is no comparo. If this will work, my two year old would really be happy. Since now I tip her over in her car seat on the same corners as the a4 which she used to stick like glue!
I had a 99.5 A4 2.8 Q Sport and it had the suspension of a Carrera compared to this air suspension of the allroad. The allroad is NOT a car for the twisties! I have had to slow down considerably when cornering.
I just came from under the car and it looks as if it is worth a try. The ar could use a stiffer
a-s bar. Do you have a part number? It would need to be for a dual exhaust A6 Avant or an S6 Avant(preferred, as it is probably larger)
I got some numbers from the A6 forum for what I believe is the 2.7t. I don't know if those have dual exhaust or not. The "psk" is some kind of sport pkg. designation. I guss I need to go look under some 2.7t A6 and compare.
u7401087
13
03-22-2006 05:40 PM
A6intel
07-09-2001 09:23 PM
