Purchasing Allroad - Level 4 light color amber
Purchasing a 04 Allroad 6sp and noticed the color of the Level 4 light is amber instead of green like Levels 1-3 are. Can anyone please advise if amber is the normal color for Level 4 or if it's an indication of a problem with the suspension. Thank you.
my 05 is the same
there is no manual 4 goes to 3 at 22mph and will stay in there and will not return to setting 4 unless you push the ^ button
however 3 will lower to 2 at 50 mph but will return to 3 if speed in reduced to around 35mph for more the 30sec
2 to 1 at 91 return to 2 if slower then 45mph more the 120sec
sounds like it is set to "manual" mode. try pushing and holding either up or down (not both ) for 3+ seconds and the amber light should turn off indicating it is set to auto height adjust based on speed
goahundred
04-08-2003 09:40 AM
