Question about ESP/ABS when driving in mud...
Old 12-05-2008, 04:39 AM
spedrcr's Avatar
Default Question about ESP/ABS when driving in mud...
02 Tip in Drive with Yoke Advan S4 tires, plenty of tread but I do realize these are not for mudding. ESP button pressed so it was "off". Level 4 on the suspension.
I got on some super fine dust/mud this time of year, where the top layer had frozen and then thawed and under the first three or so inches it was hardpan but wet. All four wheels were slipping, duh, but at the same time the ESP was active no matter what the throttle position was.
Can't we slip all four tires without throwing this car in a computer headspin? The more I tried to get the *** end to come around me, the more the ESP would be working. Anyway around this? Can't remember exatcly but I have a good software version for my ESP box so maybe I need an upgrade or something.
Anyone have an experience similar or different they care to share? I have always found the ESP/ABS to be very intrusive in this car, esp the harsh but short bumps up a driveway that turns on the ESP...what's that about.
Wish I had my UrS out there to sling some mud but it wouldn't have made it down the hill to get to the mud. Gotta love the adjustable susp in the allroad!
Old 12-05-2008, 04:45 AM
StumpJumper's Avatar
with ESP off in snow I've been able to hold slides and oversteer at will but I have an 04 manual
Old 12-05-2008, 05:54 AM
trg
trg's Avatar
I've had to pull fuses when doing ice trials. Try at your own risk.
Old 12-05-2008, 06:22 AM
ArchAudi's Avatar
Press and hold the ESP until light goes off. That's off road mode, will help in snow.
Old 12-05-2008, 06:36 AM
Member
2002ar's Avatar
Default EDL keeps working even when ESP is switched off.
You're right, I understand. To truly disable ESP & EDL, fuse(s) must be pulled.
Old 12-05-2008, 06:40 AM
4Ring Jelly's Avatar
which fuses, out of curiousity, did you pull?
Old 12-05-2008, 08:14 AM
spedrcr's Avatar
Default off road mode? Never heard/read about it. Press once to turn off the ESP and then press and hold...
to go into off road?
Old 12-05-2008, 08:53 AM
trg
trg's Avatar
Default Anything that had anything to do with ESP or ABS. Would have smoked my brake pads pretty quickly on
the skidpad otherwise.
Old 12-05-2008, 10:20 AM
ArchAudi's Avatar
Just press and hold. The light will go off in a few seconds. It's in the manual.
Old 12-05-2008, 10:22 AM
ArchAudi's Avatar
Also, in all other Audi's press and hold will disable everything. Just the allroad has the off-road.
Quick Reply: Question about ESP/ABS when driving in mud...
