Question for alroad TNXXXXXXXXXX
MAKE ANYTHING OF MY ENGLISH LANGUAGE I USED GUGL TRANSLATE WITH SERBIA / ENG, I HOPE THAT I HAVE NOT BEEN HARD TO HUMAN BEEN AND THERE WILL NOT BE A PROBLEM TO REPLY MY QUESTIONS
WELCOME TO ANDRJ WHO TAKES EXPRESS THESE REASONS AND DOCTORED BY ALROAD
Hello to all people. I'm Petar Milosevic from Serbia, and I have a problem with my alroad ...
Here's what this is about: My car does not have any problems with airbag discharge but there is another problem. When the car starts, my car slowly raises to level 2
When I want to raise a car from level 2 to level 3, some way it does happen that it does not want to raise the YELLOW LAMP FOR THE SUSPENSION OF THREE AND AFTER A TIME TAKE THE BEGINNING, AND ANY THAN AND THE AUTO HAS NOT ENOUGH ...
I think the compressor has been weakened and it can not fill how I need to lift the car. I'm interested in the following things since I read your account for days and delighted with what I read and I can only praise you and thank you. I know the following:
Where is FUSE 40A
Where is RELEJ ZA KOMPRESOR
WHERE THIS VALVE IS N111
How much compressor should the BAR have to do normally?
I wonder if the compressor should work and how much it should work to fill the cushions
I found on the Internet that RELAY NUMBER 214 FOR A COMPRESSOR AND THAT IS THAT
How can I check if the compressor is in question?
If I need some information I will add
It's alroad 2003 year
6-speed manual transmission
letter mark of the BCZ 120KW
Where is FUSE 40A
Adam Mowafy
Quattro: Turbo / Ur / Sport
03-16-2003 04:53 PM
