Radio Display says "SAFE" -- What the hell?
Have a 2004 AllRoad with about 80K miles.
Turned on the radio (factory stock Bose system) yesterday morning and it didn't really turn on. It just displays the word "SAFE" in the radio display and it also says "SAFE" in driver information system between the speedo and tach.
What the heck is this? It worked fine the last time I drove it and now all of a sudden it won't turn on and says "SAFE". Pressing every button on the radio does nothing![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Need my tunes![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Thanks in advance for the help.
Need my tunes
and then input it via the instructions in the owner's manual. No biggie.
If that doesn't work there may be a short -- if you can find someone nearby with a VAG-COM they'll be able to research the issue.
original one, on the 2004, you shouldn't need the radio code. I didn't on mine.
If it goes into safe mode, that may mean it's not connecting to the car properly. You may need to pull the headunit and check the connections in the back.
<center><img src="http://i281.photobucket.com/albums/kk202/kcphipps/Audi%20pics/audibuildstickertrunk-1.jpg"></center><p>
In this example the dafe code is 0152.
Assuming its the original radio that the car was built with.
TTGram
07-20-2004 03:43 PM
TighTT
06-09-2003 10:10 AM
Quatime
01-07-2003 10:42 PM
