rear seat overhead lights issue... any ideas?
It started a month ago but went away.
When switched on middle lights don't come on
When rear door is open nothing again
but when I turn on the front light switch both front and rear come on.. weird...
Any ideas
I am going to look up the diagrams for the lights
TIA
Any ideas
TIA
Try popping it out and reseating the connector, and/ or moving the connector up or down while it is connected to see if that helps.
This was the only thing wrong with my ar when I bought it.
If you remove the light the connector that plugs into the light.
Mine had zero functionality when I bought my car.
So I eventually got around to troubleshooting it. Pulled it down and found that if I jiggled <technical terminology> the connector the light worked.
So I found the sweet spot <another technical term.> where it worked and popped the light back in, and it has been working ever since.
no lights come one when that door is opened, <I>SOMETIMES</I>... thought you might have been talking about that sensor... still trying to fix that one
