Recommend you all check your power steering fluid level. (Long)
Allroad really performs differently if the power steering fluid is a bit low. I have an 03 allroad and had never personally checked the fluid level in the power steering unit. My experience through the years with tens of other cars was that unless you saw a spot on the driveway, no need to bother checking the level. After all, the dealer checks all the fluid levels at each service...well maybe! Friday, I started hearing a moaning sound coming from the power steering unit. Turned out the level was very low. I bought a litre of the special fluid Audi and VW use, and then topped off the fluid. Yes, that corrected the noise issue. But most importantly, it made my allroad steer and handle significantly better than ever! Gone is that slight twitch of the steering wheel that crops up around 50 MPH. And it is now very easy to steer a fine line driving through mountain twisties. Steering is no longer vague. It finally feels the way a luxury sports vehicle should. This leads me to believe that the power steering fluid level was never correct, despite pre-delivery inspection, 10K service, and two additional oil changes at the dealership. Will address this with the service manager when I take the allroad in for its 20K service on Monday. But for you fellow allroaders, I strongly recommend that you check the fluid level. Low fluid could explain why so may folks are unhappy with the steering on allroads.
9 out of 10 cars I get a day or low on power steering fluid. And with no leaks. Somehow that stuff just evaporates. Some cars quicker than others. Occasionly you see one actually leaking but not very often. Keep that fluid handy.
My "OIL IS LOW" light came on this summer, at around 20K miles, maintained by Audi on the schedule intervals. The car was 2 quarts low!!! I thought only my Porsche burned oil?..... no leaks here either, just burns some oil!! (we actually said it was probably the ghost of the Porsche sucking the allroad dry after it had gone thru all of ITS oil! who knows what cars do in the garage alone at night.............)
loss of performance though. I just make it point to check the oil every week or so and keep extra oil in the garage.
I am not sure if this is still the case (it probably is), but with the older Audi's if you put in the standard steering fluid you get at the local Autozone or Pep Boys it will eat away at the seals until your whole steering system is leaking like a sieve.
Gavin
Gavin
