Replacing connectors on the main ecu wiring loom plug
I,ve recently had a moisture problem in the main wiring loom, this corroded some of the connectors inside the wiring loom plug and some pins on the main ecu, does anyone know where you can buy some of the connectors for the loom plug, the ecu pins can be cleaned its just the loom plug, there are two sizes in the loom plug.
I,ve used a good electrical cleaner but i still get sporadical electrical issues.
Not exactly, my local garage decided to steam clean the workshop with my car high up on ramps, you would have thought it would be well enough protected but the electrics went haywire went they tried to start the car, moisture wa everywhere, everything is now fine just the corroded connectors in the plug.
Snow Trooper *Swiss*
9
09-25-2006 09:17 PM
90mtl
09-16-2006 03:50 PM
