RS6 Wheels
Not a wheel guru but looking for some RS6 wheels for my 02 AR...
Question is... will these fit?
Set of 4 Audi RS6 wheels
Diameter: 19"
Width: 9"
Offset: 44
Bolt Pattern: 5x112
Centerbore: 57.1mm
Thanks
Diameter: 19"
Width: 9"
Offset: 44
Bolt Pattern: 5x112
Centerbore: 57.1mm
Thanks
Those aren't C5 RS6 wheels, well they may look like them but the OE size for that sized C5 RS6 rim (5 spoke) is 19x9 with an offset of 35mm. They won't fit the allroad without at least a 7 mm spacer. Maybe the rims you are looking at is from a C6 RS6? ...et44 def won't fit without a major spacer (15-20 mm)
The OE 18x8.5 with an offset of 30mm RS6 rims (9 spokes that USA got) do fit the allroad with no spacers. I run these on my allroad in the winters with 255 mm wide Blizzaks....no issues or rubbing.
Also, the OE RS4 rims also at 19x9 with offset of 29mm fit the allroads with no spacers.
Hope this helps...
Hope this helps...
Hope this helps...
Hope this helps...
I picked up a spare winter set for $300...go on www.RS6.com; there are at many times sets being sold reasonably with or without tires. Post that you want a set.
You'll want the 18x8.5 et 30mm 9 spokers so you can roll with no spacers.
The 18" 5 spoke rim for the allroad is nice too, it looks just like the European OE RS6 rim....just not as wide.
I actually have a extra new set (in boxes) of the Euro-5 spoke RS6 rims 19x9 et35mm that I want to sell for $950 ($1100 shipped in the USA). You can get a set of 10mm spacers and 47mm lugs for about $200 and be golden.
Pm me if interested...I can text pix of them.
