self levling suspension light ...
#11
I had that warning once. The repair shop did a crappy job on my repair and didn't connect anything in the front bumper. Also, there was an issue with my suspension in which the rear level sensor failed and in turn it burnt out the pump.
#1 check to see if your car is level front & rear.
#12
<center><img src="http://pictureposter.audiworld.com/45465/sus_fault_codes.jpg"></center><p>01772 155 Level control pressure sensor implausible signal
and
01399 156 Compressor/Self leveling suspension relay -j403 short circuit to B+,
Anyone have a Bentley handy?
Thanks
01 ar
Brian Boulder, CO
and
Thanks
01 ar
Brian Boulder, CO
#14
took it to dealer, the next day..suprise suprise light went off before I got there!
No fault detected by dealer. Few days later battery was completely flat...cells corroded. Dealer replaced without charge...light hasn't been on since.
Coincidence ? or possible low output of battery causing sensor to light up...dunno...just relaying an experience...
01 ar tip
01 ar tip
ch7656
Audi allroad
01-29-2005 01:40 PM
