Signal/Wiper Stalk Failure(s)?
Last week I noticed my turn signals completely stopped working on my 2004 AR. The next time I drove it, the problem seemed to have completely corrected itself. Then a few days ago they failed again, this time it was raining and I noticed the wipers locked up as well and were 100% non-responsive. The problem went away after 15 minutes of driving and everything worked fine.
Today, both signal and wiper stalks went dead again -- and are still dead. Is this related to the blinker relay? Would the blinker relay effect the operation of my wipers? Wiring issue?
Could be the relay. I had a similar thing happen to me. Do your emergency flashers still work? The relay is a $35 part at your Audi dealer. It is a pretty common failure.
Hazards work.
Update: Suddenly everything worked fine on my morning commute. Come lunch time, everything's dead again. There's no erratic blinking, buzzing or any other signs of failure -- it just stops working all together.
did you check your fuse block...check if the fuses are inserted good
vag it if you can see if something code are recorded for electrical or loose connectors at steering column...
don't buy a relay yet ... check Carson Heter @ Riverside Audi .. look it up for the number.. You get AW discount should be max $30.... 88 is insanely overpriced... but I don't think thats your problem
Update: My HVAC system now refuses to work. Air will not blow, regardless of hot/cold/fan settings.
Should I bite the bullet and take it to my local over-priced somali pirate of dealership (audi exchange, highland park)?
