Since car is back I tried unplugging the Suspension Module
#11
perhaps newer software or a similar code from a same year A6. I believe that the so called ESP Energy-Manager might miss a data string from the RH control module and throws the ESP in Safe mode.
As we know Bosch, mostly everything is done by check-sum and look-up tables. If the check-sum exceeds the threshold then the electronic goes into limb mode.
If possible, he could try to back-up your ESP module SW and then put some A6 SW on it.
#12
suspension module back up and see if the problem goes away. You are saying it's not happening when you are throwing the car around where it would normally engage ESP so if it doesn't happen with the module connected then Rally_nutcase_1982 might be barking up the right tree.
#13
goes off activates snow/mud control. Keeps snow and mud under the front of the tire to stop better in those conditions. On all other audi products push and hold turns off ASR and ESP.
#14
get all kinds of wierd stuff from the wheels...i.e. like there is either no ESP at all or that it the computer is being sent garbage from the non properly coded ECU...with the RH ECU out completely I get better control...not real ESP like I am used to but there is definitely something there, as RAlly says it must go into some kind of default mode. You want a pig on ice that you toally have to control with your driving ability find a bad ECU...I could send you mine
and then you would be in business I bet...how is that for repurposing?
#18
My level control module is out, sitting in a box. I can turn off ESP, lighting up the dash light. Then I can do stupid tricks in the snow, 4-wheel burnouts, short drifting turns, etc. The light hasn't come back on, but I haven't romped on it for more than a minute or two at a time.
I'll try leaving it disengaged for a few hours and see what happens. I won't be in the snow, however, and tend to avoid drifting on public roads unless its snowy playtime.
-df
-df
#20
My understanding is that the allroad is different from your description...
There is no "off" mode - when pressed the dash lights up and that engages "offroad" mode.
I have not verified YOUR description but I think I will test it today.
