Smelly AC
Smelly AC
What is causing the smell after running the AC? I noticed on a few of my cars.
I assume some mold/else is building up on external or internal heat exchanger?
Will cleaning help?
If so: what to use and how to do it on a 2.7T AR?
Will cleaning help?
Replace the internal air filter? Just a guess...
1 Post
Some people spray Lysol into the air intake area after removing the air filter. Audi has a special aerosol for this purpose as it is rather common. Here's a commercial brand specifically designed for the job.
http://www.amazon.com/1Z-einszett-Kl.../dp/B0002Z2MKO
And an Audi bulletin...
http://dejong947.com/audi/tsb/audi.tb.87-05-01.pdf
and the product Audi uses...
http://www.airsept.com/
1 Post
Oh yes, the air intake for the cabin air, not the engines air intake.
Remove the air filter and run the system at high temperature with the air conditioner off (ECON mode) before spraying anything into the system. This dries out any condensation on the cooling coils
Read and follow the Audi Tech Bulletin even if you're just using Lysol.
knfilters
Vendor Showroom
09-13-2017 02:24 PM
doctorno
08-23-2003 01:55 PM
