Snow tires
According to my personal calculation, diameter of each size as below.
235/45R17 = 643.3mm
225/55R17 = 679.3mm (normal size for 2.7T)
@1inch = 25.4mm
If you don't mind about this, should be no problem.
Blizzak is very reliable.
IIRC, 17" is load rating 97, 18" looks like Tire Rack lists 96, I like the 100 rated I run. The heavier sidewall seems to better stabilize the allroad.
Speedo will be off i assume?
For the 3 months that I will need them in Tahoe they seem like a great option vs 1k for a new set.
1 Post
I use Nokian all-season "WR G2" 225/55R17 101V XL on the allroad dual spoke wheels
The "101" load rating is up to 1819 lbs per tire.
The "V" speed rating is 149 MPH.
I agree with PaperToast...make sure the load rating is sufficient on the tires you're considering.
Banned
i have the same just in a 235/55, dont have them on yet but they look mean
At 8000fts on a mountain, we can rarely spot RS6 with heavy snow!
Actually regret to say i don't recommend this diameter for ar.
My local tire shop just recommended the Nokian WRG2's to me for my 05 Allroad. Do you use them year 'round? How are they for the non-winter months? Just looking at them, I assume they're pretty darn good in the winter.
