Someone with VAG-COM Help, Need long code for ABS
If you have VAG-COM, can you look at the Coding for your ABS and let me know what your range number and wsc codes are?
Thanks
Thanks
I don't know what the range # you're referring to is, so I included a fault code, instead! ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
This is from an old log file I have.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 02325
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Coding: 06497
Shop #: WSC 02325
1 Fault Found:
Thanks for the reply. My original soft code was 06397... But now is 00000 and I can't recode it. Looks like ABS EBCM 5.0 is Junk. So much for a vacation this year...
Unless someone, anyone can tell me how to login and code this thing???
Have VAG-COM 409-1 registered.
DWP
01-31-2009 09:17 AM
JPRobertsons
12-16-2005 03:25 PM
