suction pump question
#12
not there beforehand. Is there any credence that the type of oil, ambient temps might be causing some gasket shrinkage (regularly hitting 0 degrees F each night)? Had also read this as possibility over on b5s4 forum. FWIW, been using only mobil 1 0w40.
In any case, will keep tracking, probably fold this into TB change which is due shortly.
#14
There are several differences in the engines after 02, and I have never paid attention to this concern on any later ones yet.
#19
...the bend in the y-pipe at the back of the intake manifold.
Easiest way to find it is to locate the large-ish vacuum line poking through the firewall (coming from the brake booster). Trace that to below the y-pipe...there's your suction pump.
Again, this is only on the auto/tips.
OneGuyInCA
16
10-20-2021 07:17 PM
drugmoney
12-19-2010 10:58 AM
hans j
01-05-2009 11:12 AM
