Third Row Retrofit complete
#15
Here are the part numbers (note: italics represent color code specific section of the part number; mine are specific for platinum/grey on black interior).
Flooring
4B9 887 105 A - SubFrame
4Z7 863 599 B - Packing
4B9 863 465 G <i>90G</i> - Compartment Floor
4B9 863 544 D <i>90G</i>- Lower Cover (for spare wheel)
4Z7 863 547 C <i>90G</i> - Upper Cover for spare wheel well
4B9 863 546 <i>90G</i> - Trunk lining (flip up cover)
4B9 857 797 A <i>4PK</i> - Flip down third row seat belt cover
C-Pillar
4B9 867 295 G <i>25R</i> - Left C-pillar for third row with side curtain airbag
4B9 857 812 <i>V04</i> - Left third row seat belt
4B9 857 781 <i>EC3</i> - Left C-pillar belt guide
4B9 867 296 G <i>25R</i> - Right C-pillar for third row with side curtain airbag
4B9 857 811 <i>V04</i> - Right third row seat belt
4B9 857 782 <i>EC3</i> - Right C-pillar belt guide
Side/Cup Holders
4B9 862 553 <i>6PS</i> - Left cup holder mount
4B9 862 554 <i>6PS</i> - Right cup holder mount
4B9 861 267 <i>6PS</i> - Left cup holder mount insert
4B9 862 557 <i>6PS</i> - Left cup holder
4B9 862 558 <i>6PS</i> - Right cup holder
4B9 857 859 <i>4PK</i> - Belt side clips
Misc.
During removal it will be fairly common to loose the clips for the D-pillar and side cargo sections into the side panel abyss. The replacement part number is:
4B0 867 276 A - Clamp/Clip
Note: Since I had a donor car some of the common items like bolts and screws were transferred without me having to research the replacement part number. Sorry for not detailing these items as well.
Flooring
C-Pillar
Side/Cup Holders
Misc.
#17
I was referring specifically just to the tailgate trim and yes, it is in great shape for what it has been through. :P
I am sure our pulling and prodding didn't help either.
Thanks again Eric.
Thanks again Eric.
#18
<center><img src="http://i10.photobucket.com/albums/a131/mnaranjo/allroad/A70-0255.png"></center><p>I have almost everything for the third row retrofit in my allroad.
escept the floor hard foam base and carpet (I will drill them to fit everything)
Giblet, can you help me with two questions?:
1- has the original hard foam floor base the shape to acomodate the metal seat subframe?
2- can you provide me with a close picture of the top belt pass piece in the D-pillar, and the distance to its base and angle (see picture)
thanks
thanks
#20
"pay forward" in the sense lend any knowledge I can to others trying to do this.
No cutting/drilling of sheet metal required.
If you have a pre-2001 A6 you may actually have the subframe in there already - just lift the carpeted floor. If it is not sitting on a flat metal surface but on a black "X" then you have the subframe. Quite frankly, the easiest way to tell is if you have seat belts coming out of the C pillars.
