Tightening Steering Wheel?
Old 08-22-2010, 08:41 AM
mpalumbo's Avatar
Default Tightening Steering Wheel?
Is there a way to tighten the steering wheel back up to stock? Without going to the dealer.
matthew
Old 08-22-2010, 02:37 PM
allroaddave's Avatar
You didn't give near enough information here, is your wheel loose on the shaft? Did you have it off? Is the airbag off? what are the circimstances behind your question and we can help you better....
Old 08-22-2010, 05:54 PM
mpalumbo's Avatar
oh sorry i kind of assumed you guys would figure it was stock and alot of miles.
it is stock i havent touched it, so normal aging. it has about 130,000 miles on it. its an 03. the steering is fine. other than just being a little less tight than we want. the airbag is on i would assume. and i never had it off. the power steering fluid is fine too.
matthew
Old 08-22-2010, 06:09 PM
thejulex's Avatar
matthew
There is really nothing that can get loose between steering wheel and rack and pinion so most likely what you're experiencing are worn out tie rod ends, the part that connects steering rod to actual wheel hub. The knuckle join gets loose at causes slack in steering.
Old 08-22-2010, 08:37 PM
mpalumbo's Avatar
that makes sense, it did seem a little worn. any recommendation as to where to get ones? again other than the dealer?\\
matthew
Old 08-23-2010, 03:25 AM
Dutch UrQ's Avatar
Also have a look at the upper suspension links. I had one that developed a "loose" spot going straight ahead. Tie-rods ended up being fine, but the play in the upper suspension links would caused some free-play.
Eric
Old 08-23-2010, 04:17 AM
thejulex's Avatar
matthew
Plenty of places. For genuine parts try:
genuinevwaudiparts.com
For aftermarket/OE:
034motorsport.com
jhmotorsports.com
ecstuning.com
partsgeek.com
Old 08-23-2010, 05:38 PM
PRAllroad's Avatar
The steering rack has some adjustment to take care of center play. The adjustment will bring the pinion closer to the rack, eliminating some play and noise. Do not overtighten for the steering wheel will lock while turning.
Old 09-19-2011, 03:36 AM
Dutch UrQ's Avatar
Default adjusting steering rack center play?
How do you adjust the rack in this case? My pinion has developed some play against the rack. Thanks
Old 09-21-2011, 11:19 AM
09mehashaw's Avatar
You could pull the 618 relay: I believe that's the one.
Quick Reply: Tightening Steering Wheel?
