Timing Belt Replacement cost
#11
Original posting about $2000 for this job .... you are getting robbed. I have this ahead of me and in Chicagoland I visited 3 different independent shops who do Audu and VW work everyday. All said it will be ~$1200 parts and labor, inlcuidng waterpumps and all other stuff behind the belt. local Stealership quoted ~$2000.
#12
I live in MA and have a great mechanic. I have an '02 allroad with 117k miles on it and just had the timing belt, idlers, water pump and alternator belt replaced for 950 bucks. He uses all OEM parts too.
Also, after that I had him replace both of my valve cover gaskets. He charged me 350 bucks for that.
The stealership quoted me 1950 bucks for the timing belt and 1700 bucks for the valve cover gaskets.
NH is not that far from me so it may be worth it for you to travel down here to save some $$$.
Everyone else, any opinions on when you should have it changed? Should I wait longer? I think it should be around 105K according to the maintenance pdf I download but I wanted to be safe.
Thanks
#13
Hi mikefmcnally, I live in MA also. Do you have alot of experience with this mechanic? I am coming up on 90K and was going to have my timing belt/water pump work done by 90-95K.
Thanks
Thanks
Good Luck!
#14
Thanks
Thanks
#15
Living in northern CA is all about paying a lot of money, so yea, there's no surprise that the price for a timing belt replacement around here is high as well. For point of reference, paying a million bucks for an "average" size house is pretty normal in my area.
As for the cam tensioner seals, the proper way to replace them is to remove the cams and clean the area thoroughly, which takes a lot more than an hour. Maybe some people have had good luck doing it the other way.
#16
ScarMcar,
Where is that shop in Marin that quoted you that price? I'm in San Anselmo and need to find a shop to do the same for my 1.8T '05 A4 but that seems high - even for here. Did you get quotes elsewhere in Marin?
thanks,
Jeff
thanks,
Jeff
#17
#18
just had my TB done last week at E2Motorsports on Long Island (Freeport)
those guys rock! only charged me $350 for TB labor!(stealership wanted $2500 parts/labor) bought the complete kit from blauparts myself. also had them do valve cover gaskets, poly snub mount, plugs,RS4 clutch, gutted downpipes and rear brakes
Evan and Dylin (brothers) do superb work for very very fair prices
car is much faster now and the clutch is superb
couldn't be happier!
804S4
25
04-09-2008 11:53 AM
iMMix
10
07-31-2007 07:25 AM
sms
07-07-2004 01:14 PM
20t, a4, allroad, audi, belt, cost, francisco, fsi, marin, q7, replacement, replacwment, san, specialist, timing
