Tools needed to read faults on my allroad
Hi,
I'm wondering which tool I need to read faults. I guess that subject been covered a lot but I cannot find it.
I would like to have the most flexible tool that I can get.
Is there a tool that only read codes?
Is there a tool that you connect to your pc and be able to read and clear codes and modify things?
How does this all works? heard OBD thing but can someone clarify.
Thanks a lot
Nicolas
Montreal
Thanks a lot
Nicolas
Montreal
Hi!
I am using this with pleasure.
http://store.ross-tech.com/shop/VCHUC.html
My friend in Japan bought 3rd party's fake profuct made in China, but he had big problem in comunication with his AR, and then finally he failed in 402mod.
So many Japanese guys repurchase Ross-tech genuine cable, after figuring out that the Chinese cheaper fake cable is just a waste.
If you don't have a laptop, you can use VAD Mobile and a Palm device. Does the same as the Ross Tech without the need for a computer.
<a href="http://www.vadmobile.com/about.htm">VAD MOBILE</a>
This one's price is so reasonable.
But looks Hong Kong product.
Does this works well for 402mod and performs any other changing code or basic setting ... etc?
Any operation manual?
Seems that this one doesn't require laptop so convenient!
Hi!
Also what is a 402mod. I own my all road for about 2 weeks and don't know much about them and previous owner have changed the air suspension to coils and a light is always on int the dashboard in regards of the height adjustment error, is that something that I can have removed by those tools?
I need more feedbacks
Thanks all
The 402 is a way to "trick" the AIR SUSPENSION into making each level lower. Good way to wear out suspension parts and tires quicker.
If you have coil-overs, you cannot do a 402.
Search for Coil-Over conversions and there should be a description of how to eliminate that light.
How about this?
http://forums.quattroworld.com/allroad/msgs/36729.phtml
Maybe he just removed compressor fuse.
Sourdough Josh
01-15-2003 06:32 AM
awest21
05-08-2001 12:09 PM
