top speed?
Most German cars are limited to 155ish (does not apply to all) the "Green Party" is responsable for that.
As for YOUR ar, I have had mine up to 110mph so it will go that fast.
Stock allroads are speed limited to 130mph due to the speed rating of the stock tires they came with. Chipped ECU will remove the speed limiter, but I'm not sure how fast they will go. Probably 150ish.
Geared too low. 150 mph is probably about max since it would be turning about mid 6k rpms at that speed. Stock powerband peaks at 5800 rpm so unless chip was able to extend the powerband it would be a losing battle to go faster.
Looks like channel 7 on unisettings will change the speed limiter, but am confused where VAGCOM comes in (other than the fact that you need to cable to apply the changes from unisettings to the ECU). What needs to be done in vagcom? Any recommended offset for value 7 in unisettings? Screenshot below:
![](https://img535.imageshack.us/img535/772/uniset.jpg)
FixedWing
28
12-12-2004 09:07 PM
exts4
11
02-20-2002 11:41 PM
4.2MingBlue
14
12-05-2001 06:06 AM
