TPSM sensor
No sensors. You need to reset the system so the car knows it has new tires and the inflation is correct.
Not a good sign. You may have a problem in the system. Do you have access to VCDS tool?
No I don’t unfortunately. I’m not too concerned because it’s part of problem I’ve had since a new engine was installed. There are intermittent fault warnings that come and go. I need to source the problem of this. The mechanic who installed the engine couldn’t find the ‘electrical’ issue which was annoying.
I had a lot is steering malfunction warning that just stopped and there were no error codes recorded. Is there a point where the steering and TPSM control meet? I also have an engine mount code at the moment.
eigenvector
09-07-2006 05:21 PM
KaMaKaZieP -ALUMIN8-
11-21-2005 03:53 PM
konger1k
08-05-2004 08:53 PM
