Transmission failure at 130k?
#12
Just replaced the clutch on my allroad. My RS4 clutch lasted 7k miles before the springs on the pressure plate collapsed. Have put a standard clutch back in for now, $1800 before tax in BC. Don't know if the extra weight of the allroad contributed to the shorter life of the clutch but that was not very long at all. Too many sprints off the line I guess. My original clutch lasted 82k, second one 34k, last one 7k, the cost of that extra 150 hp.
#13
Any DTC codes? Does it move at all? Limp mode will default to 3rd gear I believe. Unusual for two gears to go out at the same time for mechanical failure. I just rebuilt mine, since the reverse was weak. The D drum is a known mechanical failure (weak or no reverse) along with torque converter seal, both of which I replaced.
Going over the ZF clutch chart data, the only thing 1 & 2 gear have in common is the G brake. It's the same drum as the D brake, just the opposite side. It might have failed, but uncommon to cracking, since the housing is super thick on the G brake side. It could be the G brake solenoid on the valve body. If so, that's repairable simply by dropping the pan and filter, BUT, I'm not finding a solenoid dedicated to 1 & 2 gear only. They are tied in with other gears as well.
Clutch A is for 1 & 2 gear, but also 3 & 4 gear too. If only 1 & 2 are gone, it's not the Clutch A.
#14
#15
Not sure what a push guard is, sorry. I took the original package that included the complete upgrade. The only thing I didn't get was the upgrade on the manifold which was recommended for the biggest upgrade. You can check out my garage to see what I've had done to the car.
#16
Problem is, there is no service interval for the trans per manufacture. and the books say "lifetime fill" which is obviously BS, and by 100k its black as engine oil and stinks like hell. If they did dealer only maintence, garentee it was never serviced once in its life. The transmission electronics are really good at adapting shift quality with loss of fluid quality. Thus never detecting any loss of shift quality over the fluid life.
#17
#18
#19
#20
I havnt got up to speed enough to test 5th its currwently at my shop. I dont know how deep my mechanic looked at it, but is good nonetheless. I'll run this by him
