Turn Signal Troubleshooting
Hi everyone, I could use your help troubleshooting a right front turn signal that doesn't flash, but works fine in parking light mode (separate filaments). Left turn signal operation is normal. Right turn signal relay flashes fast and side and rear turn signals work but flash fast. I've replaced the lamp twice and the lamp holder once, traced wiring harnesses, cleaned connections, and checked the fuse. As I understand it, the relay is part of the hazard light switch in dash center, but I don't know how to get to it. Is the relay the type that one part of a three function (left, right, all) could malfunction? If so, how is it replaced?
Banned
seeing how you've done all the obvious replacements, my guess is with yours, the relay has to be on the fritz.
i do know you have to pull the radio out of the way to get to the innards of the dash underneath where the relay is, it might just be a matter of pulling the radio and popping the relay out from the back
Turn signal relay isn't too difficult to replace. I did it last month. Step by step instructions are somewhere on the Internet. But I'm too lazy to find the link for you. But, it's out there.
COMPUTEK::WMS
08-26-2009 12:06 PM
Mr. Malcontent
04-19-2005 03:52 PM
