Uh, HELP! Electronic immobilizer needs resetting?
Old 06-09-2006, 04:31 PM
GottaAllroad's Avatar
Default Uh, HELP! Electronic immobilizer needs resetting?
[searched the forum but didn't find anything about resetting the immobilizer]
Here's the situation:
1. Drove the AR last night no problem.
2. Gave wife 'extra' key this AM so she could use the car
3. She gets in, uses the extra key, and the AR turns over but then stalls out.
4. She's stuck and reverts back to the '89 Legend. Thank god I had a backup car for her!
5. I come home, read about the immobilizer and say 'that's what happened'.
6. Thinking my key must still work (it worked last night) - I use my key to try to start the AR - but no luck, same thing regardless of which key we use.
THE PROBLEM - the user manual doesn't say how to reset this thing!? I'm 99.99% sure that the thing was tripped when my wife used the extra key, but I don't see how to reset it!?
TIA - Steve
Old 06-09-2006, 04:47 PM
grey-2002-ar-6sp's Avatar
I think it needs to be flat-bedded to the dealer, sorry. (from my searching on a similar issue)
Old 06-09-2006, 05:12 PM
Default Just talked to dealer....
He confirmed I'd likely have to have it towed. He said try all the keys - including valet - and we did and still no go. Dealer says he'll have to reprogram the keys.
The good news - the dealer is open on Saturday and I have free AAA towing! So I'm not without all weekend..but, what does it cost to have the keys reprogrammed? Is THAT the bad news?
TIA - Steve
Old 06-09-2006, 05:21 PM
SKIroad'r's Avatar
Default for those of us that are ignorant (hijack, sort of)
To avoid this problem do you have to start the car with the same key that unlocks it? Would love to know, so I don't run into this problem.
Old 06-09-2006, 06:24 PM
Default Nope, that shouldn't be a problem, at least I hope not. My guess is, the car didn't know about...
...the extra key.
The bits of reading I did on the immobilizer are that:
. the car knows about the keys it should trust, by being 'introduced' to all of them in a single procedure
. attempting to start the car using an unauthenticated key can result in the car revoking authentication for all trusted keys
. the dealer needs to get (from audi) a s00per sekrit, time-limited code, to allow the introduction process to take place again
Old 06-10-2006, 04:00 AM
magilla70's Avatar
Default using an unauthorized key will not wipe out all the keys..
the "authorized" key will still work after trying an "un-authorized" one. All the immobilizer is doing is looking for a match, finds one...car starts. No match, no start.
In fact the ignition lock cylinder on the new A8's is not even keyed. You can put any switchblade key into it and turn it, but since they are not matched to the car, the electric column lock will not release and the car will not start. Put the correct key in all is well.
It is possible the ignition switch may be bad in GottaAllroads car since both keys are inop.
Old 06-10-2006, 04:39 AM
paulroad's Avatar
Default Did the immobilzer light on the dash light up? or flash?
When the wrong key is used you get 1/2 second of engine life then nothing.Light that shows a KEY and a Car in the cluster when the immob. is activated. Is this showing up?
Are you getting the engine light instead? IMO there is something else and not the immob. that is wrong. A VAG COM Scan may show a lot for you. It may just be a simple wire somewhere.
Old 06-10-2006, 09:37 PM
Default Thx for asking re: console lights...yes, the yellow key light was activated...
w/engine cutoff as you described after 1/2 second of run time. No other engine light...should have mentioned this in the original post.
Anyway, towed it to dealer today. They checked it and did a $130 reprogramming of the key set, and all is well now.
My guess: the original 'extra' key had never been programmed, misprogrammed (by prior owner?), or whatever. I think this is what triggered when the wife put in the extra key, and once that was done no other key (in particular, the one I had been using for 6 months since I bought the AR) worked.
That seems a bit harsh since if it happens and you're not near a dealer you are 100% screwed. I'm glad it happened at home, or else it'd been even more of a drag.
Still LOVE the AR, so I don't care about these inconveniences and/or ghosts in the machine...now I can drive it to my friends and get those H-Sports put on next week...and then hit the road to the coast and have a lot more fun along the way...
Old 06-12-2006, 06:05 AM
Synmag's Avatar
Default No. My wife and I frequently unlock and start with different keys
It never occured to me this could be a problem so we do it all the time. Frequently I have my hands full and she will unlock with her key and I drive with my key. No problems.
Old 06-12-2006, 10:24 AM
Default Thanks for all the help - electronic immobilizer reset recap
Took the AR into the dealer on Saturday and they did a reprogramming of the full key set. Now all is back to normal.
Like I said, the problem was triggered when my wife used the second key last week. As far as I know (though I'm not 100% certain), this was the first time we used the second key and it must have arrived from the seller (I bought the AR used 9 months ago...) with invalid programming.
Once the key was used, the immobilizer was triggered and we were dead in the H20.
One note: most people suggested that the OTHER keys should have worked even after the invalid key had triggered the immobilizer...but this was not our experience - both keys (and the valet key) did NOT work once the immobilizer was triggered.
Now that she's running again, the H-sports are going on mid week - yoohoo!
Quick Reply: Uh, HELP! Electronic immobilizer needs resetting?
