Update on my new noise problem: Misfire in cylinder 5 is happening when the ticking is there
when it goes away, so does the misfire. Been driving around with the VAG COM all weekend trying to figure this out.
Before I buy up parts, any suggestions?
Thanks for all the help.
2 different faults: bad Spark plug and later on a failing MAF.
In order to eliminate a possible bad coil pack, exchange it with another cylinder and get the readings again, this will confirm the Spark plug should the same Cylinder receive identical faults.
Also try to get some MAF cleaning Spray (moderation does it here).....just in case, otherwise you should see variable idle speeds and a short blow of black Exhaust fumes. But all of that is optional ;-)
AudiSportB5S4
9
01-07-2008 10:27 AM
polishadonis
04-15-2007 02:20 PM
delbeef
08-03-2005 08:20 AM
