VAG-COM has arrived, now I am really dangerous
Ran a full scan found 2 codes on the transmission:
2 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 003 - Mechanical Failure - Intermittent
17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
P1560 - 003 - Mechanical Failure
Wonder if I should be concerned on the 2nd one. May have Audi take a look.
Also checked the suspension height and received these readings in level 1
-29.0 mm Height Front1
-18.0 mm Height Front2
-23.0 mm Height Rear1
-24.0 mm Height Rear2
Went to level 2:
-5.0 mm Height Front1
3.0 mm Height Front2
0.0 mm Height Rear1
-2.0 mm Height Rear2
Should Front1 and Front2 be this far apart?
It's a cool tool that I hope to learn more about. Set the windows to lower with the key FOB. Probably shouldn't have waiting 6 years to buy one. Now onto the Passat.
2 Faults Found:
Went to level 2:
0.0 mm Height Rear1
Looks like front1 and front2 are at the far end (end beyond) of the tolerance. you might have a bad level sensor on either. I have one in my passenger rear corner and I check it every once in a while to make sure it's not too far off from the driver side. Then I just use VAG-COM to adjust it up or down to get it within range of the other side.
between level 1 and level 2 are similar.
The level cotroller will level the four corners when car is running.
1)Ignition was switched on with connector for Transmission Control Module (TCM) -J217- disconnected.
2)Open circuit or short circuit between Engine Control Module (ECM) and Transmission Control Module (TCM).
3)Incorrect or faulty Engine Control Module (ECM)
1)Signal from engine speed sensor to Engine Control Module (ECM) faulty.
2)Engine speed (RPM) sensor -G28- faulty
3)Engine RPM signal is being corrupted by incorrectly installed electrical wiring (e.g. retrofitted telephone)
