Warning lights on dash light up under heavy acceleration
Just bought a 2001 6-spd Allroad with 72,000 miles. Drove like a dream during the test drive. However, on drive home, I got into it a little more aggressively and some problems surfaced.
When accelerating hard, whether from a stop or doing a 60 to 80 mph pass in 6th gear, the engine seems to lose power above 4000rpms (surges as well) and four lights come on on the dash: ABS and Check Engine, a triangle with an arrow circling it (ESP I think), and a car icon with an up and down arrow in it (ride hieght?). Once I let up, the ABS and ESP lights go out, the check engine light sometimes goes out, and the car icon always stays on. They all reset when I turn off the car and start it back up. The car drives great when driven normal. No lights come. Even moderate acceleration is ok. It's only when I floor it does it seem to object.
Additional info, the car has an APR chip installed and I was running with 93 octane.
Thanks,
Jeff
Thanks,
Jeff
A wierd bug in the firmware of some cars made the programing do odd things. I think they were all 01 allroads that had the problem. Chech your code revision and inquire from APR if there is a new one.
Interesting. Could that mean a bad turbo? I've never had a turbo go bad on me so I am not sure what it would feel like. But if I had to guess, I would say that the surging feels as if maybe one of the turbos is not quite up to snuff. Is there a way to trouble shoot this?
out the tail pipe. Leaks in the high pressure air system from the turbo to the throttle body cause boost leaks. I posted a write-up on checking for leaks on <a href="http://www.allroadfaq.com/downloads/technical/2.7t_pressure_testing.pdf"> allroadfaq </a>. Another option is vag-com it like Trango suggested.
