The washers broke, but at least the wipers are awful
#11
I thought on the 02 and newer allroads there are no replacement wiper blades other than OEM?
My wipers don't work that well in the cold either. They both miss a spot in the center unless they have absolutely no ice on them and are warmed up. The passenger side blade has always left a 3" or so unwiped spot basically right in the middle of it's path, even in the summer. I may just get new blades to see if that is the problem, I'm not sure how old the current ones are. But they do work fine in the rain other than the missed spot on passenger side.
On the washers, mine ususally work ok but will freeze up sometimes in the morning. I saw on the list of allroad features that later models came stock with 'heatable windshield washer nozzles'. Anyone confirm what that means and if they are actually heated?
#12
#13
Yeah, it's OEM or nothing with my '04. $45 from the dealer a month ago. The right one, even only a few weeks old, is already leaving that characteristic blank spot in front of the passenger. Feh.
The car spent the night in the garage and the washers are back, so obviously it was a freezing issue. I ran the pump for a while and used up much of the fluid and dumped in some fresh stuff that is rated to -40 degrees or something, so I expect that'll be the end of the problems. I don't know where the frozen part was--if the nozzles are heated, it definitely wasn't there. I suspect it was in the line somewhere.
It was about 8 degrees when all this happened, but it's warmed up into the 20s now here in Cleveland. I'm thinking I might order up some 2001 allroad wiper arms and be done with the OEM wipers and see if that helps.
Thanks for the feedback guys.
#14
Just an FYI out there, BMW makes wiper inserts that fit the '01 blades (curved one and all). They run about $4.00 a piece, just make sure you get the correct size(there are 2 different widths, I think Audi's take the narrow one.) They are universal in size, just cut the steel insert & then the rubber approx .25" longer than the steel!!!
#15
Last night I emptied out all the cheap blue fluid put in by the dealer I bought the car from, refilled with RainX De-icer fluid. Then ran it until all the old stuff was gone and the RainX was spraying. Got up this morning to temps in the teens and all nozzles firing no problem.
Will those BMW inserts fit '05 blades?
drvai
01-08-2015 03:59 PM
Jonny K
Audi Original "S" Cars
23
04-03-2007 05:17 PM
Dave K
01-05-1999 02:00 PM
