Wastegate Control Lines
#11
Finally
Lock carrier off and changed out timing belt, water pump, pullys, accessory belt, etc. while I was in there (100K).
Pulled the turbo inlet pipe and got enough room to dremel the clamp off and pull the what was left of the wastegate control line off. Thankfully I don't have to remove motor mount or anything else. Looks like 4mm hose will do the trick but I'll have to insulate to keep it from the same fate as the last line.
#12
Actually quite easy compared to what you have been doing. Use VAG-COM to monitor fluid temp and no problem.
#13
#14
Holy Crap!
Got the old control line bypassed and everything back together. Only had to go backwards once and had to remove bumper after forgetting to put intercooler intake boxes in.
Started her up and everything seemed okay so, after a warmup to open the thermostat and top off the coolant I took it out for a spin.
Whoa, you put your foot down and it doesn't go into throttle limp after a couple seconds. Didn't get out on the highway but this thing, even at 4000 lbs, is a beast. Will have to warn my wife.
#15
Performance Before
Here's what the boost, N75 and throttle look like when the boost control line is broken.
Note that at the beginning of the pull, the actual boost climbs up above requested boost and, at about 286 seconds, the ECU figures out that upping the duty cycle of the N75 hasn't reduced boost to below requested and cuts the shuts the throttle.
Will post "after" pics as soon as I can get them.
#17
wana know a tip. hook up your pressure line, the bottom line on the n75 to the manifold behind the throttle body. like the evap line. i bet you will hit 27 psi on your first pull. trick know is to manunaly with a gas valve , turn down the pressure the map see's.
then make sure your tip is coded to 32 sport mode. makes a huge difference in the pedal responce from the tcm and a higher tq level allowed.
#18
Will look at the transmission coding though. I think that it is "learning" that it has power now but, if I don't like the sport mode, I can reset it to factory. Thanks for the tip.
Shep 1.8T
09-25-2006 09:03 AM
myfootsmells
19
09-10-2005 08:19 PM
QGMika
Performance and Tuning
07-22-2003 06:11 PM
KgS4
12
12-11-2002 07:42 PM
