Water coming in cabin air filter after car wash
It pours into the passenger side, what diverts water that runs down the windshield? There is a black plastic flange with a slot that clips into a groove on the bottom of the windshield, is it that or does the plastic piece needs to be sealed to the windshield?
All the water runs off the windshield and collects in the area of the cowl where the battery sits. There is a drain under the battery, it is important that it is not plugged up. That is all.
I am with Cameltrophyallroad on this one, When it is in a downpour or I am driving into the wind when raining the floor gets wet (pass side) My drain tube is clear, If you remove the glove box and look around that area and run water around the cabin filter it drips inside,
I would like to put silicone around the filter box but don't know how to get around the back of it, Don't want to make it worse
Add this to your quarterly maintenance list. Especially if you have trees that drop small crud. I lost an ECU and had a mildew problem due to this drain. The battery "box" fills with water and dumps into the cabin.
Water will seep under it and flow directly into the cabin air filter on the right side. When the car is new it is sealed to the windshield and water flows over it and not under. Even if water gets under it, there should be a seal under it at blocks the water from flowing down into the filter area.
Even if your drain is clear, water will still come in if the seal is defective. I had the same problem with my 2002 Allroad. I seal the entire width of it and also around the cabin air filter shroud. 8 months no and now leak.
vtraudt
24
04-24-2022 11:12 AM
98Quattro
05-07-2008 03:29 PM
Asicks2.7T
06-02-2005 01:23 PM
atgmartin4.2
05-22-2005 02:18 PM
