What is the correct ride height measurement from the wheel opening bottom center to the ground
on level 2? All four 17" tires (10K miles) at 29 psi. Car running on level ground. Full tank of gas. No one in car. Rear cargo area empty. Stock suspension settings (no 402 mod).
I measure:
FL 28-1/4" FR 28-1/4"
RL 28-3/4" RR 28-1/2"
Is this in tolerance? Is it adjustable per corner?
I measure:
the 402 is the distance from the center of the wheel to the the fender lip. Yes, it is adjustable via a VAG Com Cable. It is the the 402 mod precedure. It is within spec when they are +/- 5 mm
Instruction in the link...<ul><li><a href="http://allroadfaq.com/downloads/mods/402_mod.pdf">402 adaptation.</a></li></ul>
SLPR S4
15
08-21-2005 07:38 PM
Norcalguy
01-01-2002 11:56 AM
DAP@EPL
27
09-26-2001 10:03 PM
