what is the problem in my suspension?
Old 11-22-2017, 12:51 PM
alfasquadra's Avatar
Default what is the problem in my suspension?
audi allroad A6 quatrro 2.7 tdi year 2000 model B4
have this errors:
01400- suspension level control 11-10 - control limit not reachead - intermitent
01577- tur-off due to over - temp 35-20 ---intermittent
01772 - signal from level control pressure sensor (g291) 27-10 - implausible signal - intermittent
Old 11-22-2017, 05:14 PM
Banned
PaperToast's Avatar
compressor is working too hard, hence the overheat code
prolly have a leak in the system somewhere
the other code, didn't remember off hand, sure someone else knows
Old 11-22-2017, 06:22 PM
John535is's Avatar
The compressor is not providing enough air pressure (01400 & 01772) as a result the compressor is running too long and getting too hot (01577) there's a temperature sensor mounted on the compressor.
So you need to work out if the compressor is working but you have a leak (as per papertoast advice). Usually this will become evident as one corner will droop that indicates its either that bag or the air line to it or, these compressors are getting quite old now and the ring in the compressor bore has worn out therefore not providing the pressure. The compressor is very expensive to replace but there is a kit available to replace the ring and gasket. do a search for bagpipingandy (this site or ebay) he makes and sells a kit many have used myself included. There are probably others available. The kit is quite cheap & easy to install as a DIY.
Old 11-28-2017, 11:08 PM
amiram's Avatar
Code 01772 will disappear when the pressure leak and the compressor will be repaired
Old 11-29-2017, 01:18 PM
i have do nothing...and now work normally!
Old 11-29-2017, 08:32 PM
amiram's Avatar
Do not be happy too soon, The air springs pressure leakage is a little tricki
Continue to follow the press leak.
johnd64
01-13-2019 08:46 AM
jlbell
10-20-2018 06:33 AM
MainelyA8
08-14-2016 08:10 PM
milellie111
10
04-07-2015 08:11 AM
ertatta
Audi allroad
10-02-2013 05:00 PM
Quick Reply: what is the problem in my suspension?
