Wheel fit question
I'll these fit my 04 ar? Same bolt pattern but 43 offset.
http://reno.craigslist.org/pts/4487926000.html
Help appreciated.
Help appreciated.
The allroad uses a low offset wheel (ET) due to the unique wheel bearing housing geometry. When fitting wheels with higher offsets, spacers are generally the rule. This link should be of some help:
http://allroadfaq.com/content/wheelstires.shtml
Would I be in danger of hurting anything if I put the new wheels on as is and took it for a drive? Assuming of course I looked over the clearance first for obvious rubbing spots
The common interferance area is the front wheel bearing housing (a.k.a. "upright") to the inner wheel lip. ET25 is the allroad offset with the 7.5 width wheel. Wider wheels and higher offset is going to close the gap or cause an interfernace. You will probably not be able to spin the wheel if you tighten the lug bolts.
MatthewZ
Wheels & Tires Discussion
12-17-2019 01:39 PM
Are offsets on wheels such as ET38 measured in millimeters...so et30 versus et38 sticks out 8mm more
Leester
05-20-2005 05:09 PM
