wheel fitment issue
I am looking to mount a set of 5Zigen wheels that are 19x9 with an ET of 38 on my 2001 AR. Does anyone know what size spacers i would need and whether or not I will need longer bolts?
Any info woould be most helpful.
Here is a link to the wheels I have.
http://www.5zigenusastore.com/index....4x100-237.html
Depending on what width tires you want to run, you should be looking at around 20 or 25mm spacers... Which would require longer bolts or the spacers that bolt to the hubs and you bolt the wheels to the spacers.
I have 19x9 et41 with 25mm spacers and 275's for tires and they fit perfect IMO, so your wheel sticks out 3mm further than mine, so you should be able to get away with a 20mm spacer.
http://allroadfaq.com/content/wheelstires.shtml
Looks like the wrong bolt pattern. Check hub center bore too http://shop.achtuning.com/HR-DRA-Ser...l-Spacers.aspx
Buy 20mm bolt on spacers and you are able to run stock lug bolts.
Steve_Ag Arrow
12-11-2007 08:16 AM
Spacers ? Is it better to get the bolt on kind or the one that just slips in between the rim and the
maaliish
05-04-2005 09:03 PM
