who here is running 15mm spacers?
Old 02-10-2004, 03:03 PM
Dutch8griffin's Avatar
Default who here is running 15mm spacers?
Josh sent me some hmmmmmm 15mm spacers. obviously i cant use my 10mm bolts?
HEYA JOSH SEND ME SOME BOLTS!!! =^)
Old 02-10-2004, 04:39 PM
Stätus Josh
Guest
Posts: n/a
Default they are not 15mm, they are 12mm!
And your bolts should work fine since stock length is 28mm and the bolts you have from us SHOULD be 40mm! 28mm + 12mm = 40mm Call me and I'll go over the details with you. I'd like you to confirm bolt length if possible!!!
Old 02-10-2004, 06:03 PM
RMcQ's Avatar
Default I have 15mm spacers sitting in the garage.
with my BBS wheels the 40mm bolts that came from H&R are not long enough. I had to send them back. I think this wheel must be thicker than average since a 40mm bolt only left 12mm of thread lenght after the spacers. My OEM wheel/bolt combo has 19mm of threaded lenght that goes into the hub.
I need to get 7mm more length for a total of 47mm but H&R doesn't make a 47. Neither does FK (Josh's product) from their website. I'm not sure what to do.
Old 02-10-2004, 06:14 PM
Default weird... says 15 in size... no 12...
YGM! ya fellas sent them to my old address! hehe
Old 02-10-2004, 06:17 PM
ch7656's Avatar
I'm gonna guess they started with 15mm & machined them down...let us know
Old 02-10-2004, 06:54 PM
Stätus Josh
Guest
Posts: n/a
Default you are the winnar!
You are correct Chris!
Old 02-10-2004, 06:56 PM
Stätus Josh
Guest
Posts: n/a
I'm pretty sure that I can special order some for you
Old 02-10-2004, 08:08 PM
AudiWorld Expert
Milpitas2.7T's Avatar
Default Being here in the last 6 months or doing a search would of revealed that answer
You sending me any spacers to quote on? Going to my friends shop on Monday (current plans). Need to network his new shop and machines, soooo
Old 02-10-2004, 09:17 PM
Stätus Josh
Guest
Posts: n/a
Default I'm supposed to have the newest batch back tomorrow
if I do, I'll send you a set. Please email me your address!
Old 02-10-2004, 09:48 PM
yzf996fltri's Avatar
I have 15mm spacers and with my OZ's I'm running 55 mm H&R bolts.
Quick Reply: who here is running 15mm spacers?
