When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
yes everything else is the same. The only difficult part is removing the pinch bolt from the upper knuckle. It can either slip right out, or be simplying maddening.
See my last post.... I think the lower rear most are the same part except for the bushing? Do you by chance have a picture of the AR specific one out on the bench next to a standard C5 A6 one? I would love to see that if someone has it.
I just held a B5 A4 unit up to my AR (laying on the ground quick look) and it seems the same. ????
I've emailed PureMs about this exact thing. They informed me that both the allroad's lower fronts (front & rear) are different than the S4's and A6's.
I priced them a while ago @ approx $288 front & $346 rear or whatever you can get them for at your local Audi Dealer. Pricey things!
And further reminder: Watch out for that pinch bolt! It will definitely try and bite you on the....well...have a great day!
I'm going to drag this topic up to the top again. I was hoping this thread would give a definitive answer to the original question. What is the dimensional difference between the allroad lower front control arm and all others of the same era?
Is it the cone shape and size at the upright?
Is the distance between the chassis and upright different?
Is there a clearance issue because of shape or geometry?
I'd really like to know the details. Perhaps a B5 arm can be modified to work (change out the bushing?). I'm the first one to dive in the VAG-Audi parts bin to keep my fleet running w/o draining the mad money budget.
The only way for me to own one of these is to dig for alternatives that keep me away from the dealer.
Thanks
Chris
Hey Chris,
you can always check and/or compare them by checking out part numbers from this company. Or give them a call ...
The aluminium track control link has been reinforced in cross section. The ball pivot cross section has been enlarged and the joint angle adapted to the kinematics. The suspension strut eye is lower and the mountings for the connecting link and the level sensor have been moved inwards (to allow free access of the connecting link to the suspension strut).
In the case of (aluminium) guide links, the cross section of the ball pivot has been enlarged. The joint angle has been adapted to the kinematics.
The joint angle of the upper, front transverse link has also been adapted to the modified kinematics.
I went ahead and pulled the an arm off my allroad today. I compared that to an arm off a 98 A4.
There are a number of differences. Some obvious and others very slight.
The biggest difference is the vertical position (z axis for the kinematic nerds) of the strut attachment. Not being able to pickup the center of the ball joint accuratly, I lined up the inner bushing and the shock bushing. The joint appears to be ~16mm off from the other arm.
Also as stated in the Audi literature, you can see the anti-roll bar link boss is futher in on the allroad arm. The ball joint is obviuosly larger as stated.
The ball joint cone geometry matches. While there are some cross section differnces, I didn't see much in what I consider high stress areas to be concerned about. If the A6 uses the A4 arm then the allroad on the street shouldn't stress it any higher.
The distances between the bushing centers out to the ball joint looks identical.
Holy smokes, not to ultra necro this but damn thank you for taking the time to clear this up! Immensely helpful. I own two of these pleasure sleds and well, thanks again!!
Same thing here, should be other side but either way BOTH sides are fully out like that. Wow huh. For laughs, check out THAT chassis mount bushing on front lower control arm…
This sort of bushing damage comes from tow truck drivers hooking onto the lower control arm. Both sides are pulled forward.
I'd really like to know the details. Perhaps a B5 arm can be modified to work (change out the bushing?).I'm the first one to dive in the VAG-Audi parts bin to keep my fleet running w/o draining the mad money budget.
Passat arms are no different than the B5/C5 versions when it comes to the geometry. You'll still have the same issues of binding the ball joint at the suspension travel limits and the swaybar attachment points.
